Highly doubtful a gas station would do it. Plus in all honesty The adjustments are so miniscule that its pointless if your only gunna run a tank of it every once in awhile if your going to use it all the time though...in that case I suggest use your best judgement. HEED THIS ADVICE THOUGH: MEsS WITH THE STOCK AFM AS A LAST RESORT!!!
Oh and toyota told me today that recommended current fuel for "o-ptimum" efficiency, for the 7MGE and 7MGTE whether newer, older or rebuilt is mid grade 89.
(Use the mid gade for your location, my 89 is based off the following fuel availabilities: 87 Octane[LOW] 89 Octane[Mid Range] 91 Octane[Performance].)
Anyway use whatever your comfortable with I have always used 89 on my 87 N/A but if your turbo i suggest using your bat rope. :-) I mean errr the highest NON RACE octane available (i.e 91)
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
