Das....just swap in the 2JZ...its cheaper and its easier. The V-8 swap is a p-ain in the arse. The wiring is diffrent and if you dont have alot of time than the V8 is not something you want to do.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
