Thread: 2 questions
Old 10-28-2006, 07:27 AM   #1
Isphius
Isphius's Avatar
The downpipe will add quite a bit of power. It does this by increasing flow, And allowing more boost out of the the turbo because there is less pressure on the other side of it. Get a 3" dp, 3" hi flow cat or test pipe, and a good 3" exhaust, And youll boost high enough to hit fuel cut. Also about 280-290 hp. not a bad 1000 ish investment for 50-60 hp. I also have an ebay air filter adapter, with a K&N filter on it. Never got to test stock. You will also see a nice gain from 2.5" intercooler hardpipes. You can get cheap DIY kits on ebay for 80$, Or the 300$ cooleze kit. The stock IC piping is terrible tho. lol.
