The fluttering and dying roblem is a common sym-ptom of a vacuum leak or a leak in your air intake hose or air intake maifold. check those out for any leaks , including bad gaskets.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
