Old 11-02-2006, 11:34 PM   #3
ZauggIt1
ZauggIt1's Avatar
ZauggIt1 is on a distinguished road
You should be able to pull it off. Just get a breaker bar on the harmonic balancer bolt and have your son turn the crank over slowly while you are fighting with the pan. I know that i have done it both ways, and it is easier i think to just pull the motor. That way if the motor needs anything else, you can do that at the same time. Anyways, hope this helps.
Drive it like you stole it!!!
ZauggIt1 is offline   Reply With Quote
