Originally Posted by SupraBoy
ok so i have seen the thread where the guy talks about his own custom made pvc pipe intake and was wondering if anyone could describe how to do this and/or post pics...
it would be greatly appreciated...what are the up and downs of this...will it be better than the stock intake that came on my 1984 supra...thnkx
also when i start my supra it idles really low for a second....then it shoots up and then goes back low to where it almost dies...so pretty much i cant keep it at the right idle unless i have my foot on the gas right holding it there....what could cause this and how do i fix it
i done few custom air intake pipe for my mk2... and also turbo pipe too...
well first of all... you need to have a bent machine... were you can bend the pipe... thats the first thing you need to do...
second... you need to measure n cut the pipe n bend it the way you want it to be...
about your idle problem...
one thing... maybe your idle is to low... i mean your degree on pulley... maybe way below normal... or maybe its way to high....
sometime you have air leak it does that too... i mean your air intake leaking somewhere....
and sometime your distributer not in the right mark.... i mean your rotor...
and sometime its your spark-plug too... it goes bad.... and it didnt have enough spark...
check this easy thing first....
