is it -4 inhg?
if so you have an intake leak... so your air that you're pulling in is going out before the combustion chambers
(tech tip: it's not the compressor on the turbo that makes boost, it's the combusted gasses hitting the turbine that make boost
you should hear it wooshing tho and normally it would raise the idle
do a diagnostic and check the codes if you haven't done so already
