Old 11-08-2006, 09:51 AM   #13
f00g00
Default CB popping?
I didn't know there was a circuit breaker installed on the Supra but scince yours won't stay engaged then you have a short circuit. I havn't seen the scematic for it but you will have to repair the wire or not have power to the items on the circuit. Disconnecting the negative cable will not help reset this scince its the power after the breaker that has found a ground and is overloading the circuit when you try and reset it. Where exactly is the breaker?
