11-09-2006, 11:56 PM
#5
Originally Posted by pwpanas
Two possible ways to determine the problem quickly/efficiently would be to either find another Mkiv Supra owner in your area that is willing to let you take his/her dash apart so you can compare yours to his/hers ... OR ... get a set of TSRMs for your Supra so that you can compare the step-by-step instructions of the dash disassembly to what you find in your Supra.
Unfortunately, it'll probably be very difficult for anyone to determine exactly what you're missing from reading a few typewritten words. Could post some pictures?
Here are a couple of behind-the-dash pictures for your reference:
Again, if you could post some of your own pictures that would probably help to figure out what you're missing...
On the top of your deck.
What is the Below Antenna Box(brown)? What sensor is that(white)? that is what im missing?
