if the knock sensor works the same as the ones on GM cars then yes it could. on GM cars the knock sensor is what controls the advance and retarding of the timing.a missing vacume hose can do the same thing. i know if your air filter tube is not on or lose the car will stall. forgot to tighten mine up after replacing the air filter
