Originally Posted by Dom
just worndering what are the advantages of fitting a greedy bcc ,is it worth while doing ,any opinions on this
All on it's own, the BCC won't do anything at all for your Supra. With no other modifications, it'd be a complete waste of $ and time. On the other hand,
IF you're planning to do another modification to raise your Supra's boost level above about 14psi, then a BCC will be extremely useful. A properly installed & configured BCC eliminates the oem fuel cut that would prevent your Supra's boost level from exceeding 14psi. So...you asked if it is "worth while doing" and the answer is "yes"
only if you are also planning to raise your Supra's boost. You also asked for "any opinions on this"; unfortunately I can't provide you with any opinions, only cold, hard facts and
a link.
j/k lol
