i have the same problem to, ive just kinda ignored it. but ive found it never does it till the engine is warmed up, ill drive it normal and then ill pull up to a stop sign or a light and it will just drop from a 700rpm to 500rpm and it will idel very rough, i found just to push on the gas and let it sit at about 1000-1500 rpms and let the oil pressure sit for a while and let it off, and it will fix that problem for a while. but i have had it die but it will turn itself back on.
i think my code still is just the cold start sensors
7MGTE - 500hp  never dyno'd
fidenza cam gears
