Originally Posted by XtreeX
Yep, just did a diagnostic and everything came up normal it just blinked repeatedly... i'm so scared LOL!
When you jump the terminals to recieve codes ,the check engine light will flash every 0.25 seconds to indicate all systems normal.You had a pretty decent part of the engine apart and it's not impossible it was put back together slightly off.Does the car idle and respond as it did before the work?I would be inclined to suspect the timing or fuel delivery ,but I've been wrong before.Let us know any more symptoms that pop up ,and good luck.
