Old 11-12-2006, 03:26 PM   #4
j3pz
no you wont hit fuel cut after 9 psi. ppl boost up to 15psi on the ct26 before fc, however the ct-26 is said to lose effeciency after 13psi. also if you've already retorqued the head turnin up the boost a lil will be fine. and ive heard the stock internals are good up to i think its 500hp but im sure if you get up that high you may have already changed them
