Old 11-13-2006, 08:35 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
The first thing you need to do is have the crank crack tested, unfortunately if a bearing has spun that would indicate excessive load on the crank and con rod. I assume you stripped it down due to a knocking noise at about 2k-3k revs or did the engine seize? If there is bearing metal swaged into the crank journal then you will need all the journals reground to the same size. + .020 thou or + .040 thou. But first have the crank tested and let us know how you got on, check this link out.https://www.toyota-supra.info/forums/showthread.php?p=32730#post32730
