Originally Posted by boosted5mge
I definetley have a a blown head gasket. I guess I am just going to buy an SCE titan. Also, before the head gasket blew I was having a real bad miss from idle to about 2500 rpm then it smoothed out. I have change the plugs, wires, cap, rotor, played with fuel pressure, tried to adjust timing a little. I was wondering if anyone else has ever had a mysterious miss and what it was when they figured it out. Thanks
run a compression test it will give you alot of info about your engine
