Thanx yall, After I edited the post earlier I went out and felt around, sure enough there was a bolt on the bottom side closest to the firewall. When I pulled it out I found that a small hose and been broken bout it has like an inch disk kinda thing. I couldnt find anything about it in the book. Ill try to post a pic later. Will a gasket set from the local parts store be good? Or do yall recomend sumpin else? Is there an upgrades to the sytem that I can do right now. Im going to port them out, but I was wondering If there was a diffrent t-body, or intake? For ex. my buddy has an 87 300z. He removed his stock intake, t-body, and dist. and replaced with pathfinder items, which added alot of power. I was thinking about fabing an aluminum intake.
Id rather die on my feet then live on my knees
