ok I just restarted my ECU last night by disconnecting my battery. I now dont get any codes even after driving the car for a while
. I did however do a compression test and well that didnt come out so good. My car was 125,125,125,125,125,125... I know that the min required is 128, so lets hope that the car lasts untill summer time
. The car however does still die sometimes under boost, Like I described above in my last post. And yeah my car does still make the pshhhh... sound
, so I dont think my blowoff valve is stuck.(Correct me if I am wrong, but isnt the stock one a bypass valve since it doesnt vent pressure to the atmosphere?) Any other suggestions on what might be causing my problem?? I dont think that my low compression would cause my problem.
Thanks.
