Originally Posted by tellfromchico,ca
you can also feed it through with the speedometer cable just have to poke a hole through the boot
The speedo cable hole/boot/gromet was what I was going to suggest. The whole itself is plenty big for more cable. You may be able to squeeze your power cable along side the speedo cable current hole in the boot/gromet. If you can avoid taking that boot/gromet out do it...real pain in the butt to get back in properly. I would also feed your power wire (tape about a 3 inch stiff something to poke through)...feed from the outside (engine bay) in...then contort your body like some yoga dude under the dash and pedals, find it and pull. Good luck.
