Old 05-11-2005, 08:11 PM   #6
monkihead
SP58GT
monkihead's Avatar
Originally posted by supersupra@May 10 2005, 10:05 PM
thanks guys, even if the 1jz is better standard, isnt the 7mgte bigger (3 litres verses 2.5 litres??? )
if the 2.5 is capable, you may be able to bore out the cylinder to make it a 2.6 or 2.8. it would change your compression ratio, but you'll gain power in different rpm ranges.
monique- better off dead
