Old 11-23-2006, 12:07 PM   #1
SupraTT/Iceland
SupraTT/Iceland is on a distinguished road
Default Supra Mkiv Single Turbo 71GTS .81 A/R
Hi guys again. Been a long time since i posted
but here is an update on my Supra and some Pictures from my build up :P
Mod list
Boost logic 71mm GTS .81 A/R Single Turbo kit
SUS321 Tig Welded Tubular Header
HKS 50mm SS Wastegate
4” Stainless Steel Downpipe
4” Stainless Steel Midpipe
4” Aluminum Intake Pipe with Anti-Heat Coating
4" Boost Logic Polished Exhaust
4" AEM Dry Flow Air Filter
PHR Stage 2 Complete Fuel System
PHR 17.5mm ID high flow fuel rail upgrade
-6AN Stainless Steel braided fuel lines
liquid-filled fuel pressure gauge
Siemens 850cc fuel injectors
Dual Walbro fuel pumps
Aeromotive EFI fuel pressure regulator)
AEM EMS (Engine Management System)
AEM Map Sensor - 3.5 bar
Greddy 3-Row Front Mount Intercooler Kit
Crower Springs and Retainers Set
HKS Camshafts 264 Duration
HKS DLI-2 Twin Power Ignition Amplifier
PLX Devices R-500 Wide Band Kit
HKS Racing Blow-Off Valve Type 2
HKS EVC 5 - KPA Measurement (Electronic Boostcontroller)
Fidanza racing lightened Flywheel
Stage 3 Pro Clutch
Boost Logic Crank Pulley
NGK Model 3330 Spark Plugs
ARP Head Studs
Titan Motorsports 2JZ Cam Gears
Cusco Strut bars
Blitz Dual turbotimer
Toyota Supra TT ?96 BL 71GTS Single Turbo 54 k miles
BL 71GTS .81 A/R Turbo // HKS 264 Cams // Greddy 3-Row // PHR Stage 2 Fuel System(dual Walbro,Siemens 850cc Inj) // AEM EMS - 3.5 bar Map
SupraTT/Iceland is offline   Reply With Quote
