Thread: Bad Water Pump?
Old 11-25-2006, 06:41 PM   #8
j3pz
good advise as always^
i changed my water pump about a year ago, leaked from the same place. the most difficult part is the bolts holding the pulley on, as it likes to turn when you are trying to undo them. i used a screwdriver between two to keep the pulley from rotating and had someone else use a ratchet to loosen the bolts, after that its pretty easy
