first... try to use a starting fluid and spray on the thortle body n one person start the car while you spray the starting fluid on the thortle body or the air intake...
second... disconnected the fuel line n turn on the ignition key... and see the fuel line that came from the back of the fuel tank to the fuel filter... to see if there is any fuel coming out... if there is then it means that your fuel pump is good... n its something else... if you do that and you dont see anything coming out on the fuel line then it means that your fuel pump is died....
try the above part first and save yourself some money....
