you mean use the 7mgte ecu on the 5mge engine...
if you use the 7mgte ecu on the 5 or 6mge turbo charge motor then it wouldnt work.... due to the ecu wire-harness....
why dont you use your own stock 5 or 6mge ecu and up-grade some injecter parts and do little re-programing on your stock ecu...
save more money....
