Originally Posted by pwpanas
That doesn't sound right. Are you sure the clutch pedal is adjusted properly?
Yes. That play should not be present IF the clutch was properly installed & adjusted. Who did you take it to?
What "Standard Flywheel" were they referring to? The South Bend Kevlar clutch doesn't come with its own flywheel, and a brand-new oem flywheel should be perfectly flat. If you installed a flywheel that is not flat, then yes, that could also make a difference.
They said they had to adjust it slightly. I took it to a local garage. No i bought the 'RPS Cyn-R-G Segmented Flywheel for 1993-98 Supra TT, the one you suggested, and since this is specifically designed to fit the Supra TT, i don't really see why there should be a problem. The flywheel they were talking about was the orginal "stock" one.
Would you recommend that i change the fork 1st and see how it is, and then perhaps the Slave and Master if need be.
cheers
T
