Leaking Oil
[img]images/icons/icon1.gif[/img] Leaking Oil?
My 94 Supra TT has been leaking a little oil at the Valve cover for some time.
When I took off the valve covers to replace the gaskets around 130,000 miles I discovered the valve covers where just loose on the inside corner nuts.
I replaced the gaskets anyway and put it all back together. Be sure and order new valve cover breather (crossover) hoses before you start because they are usually brittle and your local Toyota dealer does not stock them. Try Champion Toyota 800-327-2087 ask for Jeff.
