what i mean flush the tranny fluid is that... once in the blue moon.... i do a tranny gear oil change.... on my 5speed tranny.... and also the rear dif.tial too... on the 5speed tranny there is a bolt from underneath the car... you need to lose it up... and also the one from the side of the tranny where you can pump a new gear oil to it... untight that one too so you can pump the new fluid aka gear oil to it...
also the rear dif.tial too... i do the same thing... when i first got the car and change the rear dif.tial gear oil... the gear oil is blacky as black.... after i do a change my car running little bit better then before... now i happy with it...
on my other automatic supra... i does change my transmission filt.. and it comes with the kit.... kits = transmission filter and the transmission gasket...
