what i use to have to do was disconnect the alarm if you take the panel off under neath your steering wheel.. on the right side slittly behing the steering wheel you should be able to feel a plug i use to unplug that for a day and usually that was long enof to reset the alarm or try disconnecting the battery for a little bit if it starts after a couple hours its your alarm but dont go just by the battery try the other way to
