Thread: riddle me this
Old 12-11-2006, 06:23 AM   #1
jeepkaiser65
jeepkaiser65 is on a distinguished road
Default riddle me this
I have tried this
http://www.toyota-supra.info/forums/...read.php?t=323
and this
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/
but didnt leave this out to try
http://www.toyota-supra.info/forums/search.php?
Im showing no codes, and havent gained to much info from the other 2. I have the engine at tdc on the compression stroke, The notch marks are align with cover #3. The balancer is at 0. The crown of the piston is at top, but the cam lobe is not visible in the oil filler neck. So I try to start it and it backfires and backfires, and ....well it dont run. Im definintley geting spark(shocked myself purty good). My injectors are working and getting fuel(purged at the banjo fitting), and Im getting air. Now thinking mechanicaly, The only way for fire to come up through the plentium is for a valve to be open, and even though the lobe aint pointing where it should it is is oppisite and dosent look like it has the valve open, but who knows??? Im about to donate this car to my jeep for crawling practice...
Id rather die on my feet then live on my knees
jeepkaiser65 is offline   Reply With Quote
