Yes, you can leave the motor in. Unbolt the trans crossmember and lower it on a jack until you can get at the bellhousing bolts up top. Don't forget the starter.
It can be done in a day if you know what you're doing, take your time. Make sure you have all the parts before you start. Also a good time to replace the rear main seal.
Nate
