Old 12-18-2006, 01:38 AM   #1
Murd
First check to see if your front marker lights come on. If they don't then check your fuses. If your front marker lights DO come on, check your wires at the back to see if you're getting current to em. Use a test light, they're cheap to get. If you're not getting current at the tail light, but you are getting marker lights up front, you'll basically have to work your way to the front checking the wire to see where the short is. Or to the back if you know where the wire originates from.
