Thread: Oil leak(s)
Old 12-19-2006, 08:04 AM   #1
mattapo
mattapo's Avatar
mattapo is on a distinguished road
Default Oil leak(s)
I am having a problem with an oil leak on the exhaust side of my engine from the front, it looks like it coming from the back of the water pump.
I have replaced the seal on the front of the engine behind the plate behind the cam gears,
I do have the leaking cam seals and will be doing those soon.
could this oil be coming from the cam seals, there is quite a lot of oil loss.
Where elso could it be from??
its not from the cam box's
its not the head or block.
I want to fid out as much as I can about where it could be coming from befor I get into it as I have to remove the radiator to do this task (its in a hilux)
Cheers, Matt
mattapo is offline   Reply With Quote
