Old 12-27-2006, 09:42 PM   #4
IHateHacks
IHateHacks's Avatar
Thanks for the reply. I thought my supra was special or something, turns out Toyota is just as bad as Chevy when it comes to the details. I was going to cut them and solder but using connectors sounds better just in case this job has to be done again in the future.
Here's where I'm at. Its hard to get things done working out in the cold when the sun goes down at 4pm let alone doing this between my regular job and working out at the gym.
I'm torn between getting a dealer head gasket or getting a metal HKS 1.2mm one. I'm also contemplating upgrading the stock turbo with maybe different compressor and turbine housings or maybe getting a whole new one. The more and more I pull parts off the more I realize everything is in need of either rebuilding or upgrading. Next pic will be with the head off.
