Then it looks like I'm using a stock gasket.
I was going to check both the block and the head with a straight edge myself and if they were not warped then I was just going to clean it up myself. If the head surface is bad then I was going to send it out to get machined. If the block surface is bad then I'm going to buy a JDM 7M from osaka.
I am buying ARP head bolts. TSRM says 58 ft-lbs but everyone here says that is too low. Any suggestion on torque specs with a stock gasket.
