Old 12-29-2006, 04:56 PM   #11
rnoswal
rnoswal's Avatar
Well, since you have the head off, I'd put a top dead center detector on the engine, then put a short 2x2 (wood) in the cylinder and turn it until the piston pushes the piece of wood up to the detector and that will stop it from moving. Then just keep applying pressure until the bolt comes loose.
Good luck
Russ
