Well I finally got the crank bolt off. To anyone that wants to know how to do it I will tell you. First though, I would like to say what did not do it. 5 different impact guns-nope. Car in gear, ebrake on, someone standing on the brakes-nope. Did not get the chance to use the starter bump method. This is what works and what will work every single time-crowbar in the flywheel through the starter hole. Worked so good I think Im going to patent that procedure. Walked the crank pulley off with 2 flathead screw drivers. Had timing belt off in less than 5 minutes after that. I was messing with this crank bolt for 4 days, but now that its off the head is ready to be lifted off. I just don't have someone to help me lift it. I can do it myself, I bench over 205lbs atm, I just don't want to risk banging it into something like the radiator support or the fender. Loosened head bolts in the order shown in the TSRM and did it in 3 passes. Did not need the SST for the head bolts, a NAPA 10mm allen head socket worked just fine for $4.65. Will have pictures in 2 hours.
Thanks for all the suggestions.
Edit: And yea Toyota of Wallingford (yet again) sucks bad. Walked into the parts department, asked if they could get SST's and all I got was a bunch of BS. First I got "No, nope." Then I got, "AHHH Toyota is closed today I can't do anything." Then it was, "They are so much money you won't want to buy them" Then I got, "Gimme your name and number and I'll get back to you" Yeah right. Does anyone else have a problem with buying SST's from their dealership?
