Old 12-31-2006, 06:26 AM   #137
quiescent_87
quiescent_87 is on a distinguished road
Default Drifting teqniques.
There are couple of drifting teqniques i use... the easiest one is the handbrake. but you can try to powersteer it. when approaching a turn, steer the opposite way then steer into the turn hard and pop the clutch, make sure not to do this on a skinny or busy road cause you might slide out too far the first couple of times. if you have any more question email me and i will gladly explain more tecniques.
quiescent_87 is offline   Reply With Quote
