If you have a clogged cat and you take the o2 sensor out it gives the exhaust an extra place to go. But since you have no cat you can rule out that idea lol. Also check the above mentioned, boost leaks, plugs, wires, air filter, etc. Make a video of the problem if you can. Does the car miss? sputter or shake? or does it just stop revving up like if you dont open the throttle all the way?
