Originally Posted by kornkid
the ecu should be able to handle it just the way it is. the uprgraded rrfpr (rising rate fuel pressure regulator) should be enough to get it to run right. if you want to get more boost than 9 psi you would want to look into a super air fuel controller (safc) or the possibility of swapping in a 7mgte.
should be able to handle it???????do you know for fact! should be enough to get to run right!??????????only tell people if you know for fact cause if not guys like you dont know unless you built it and ran it to say yes this works.not what you replied to this guy lookin for solid information!
