It sounds like the infernal pressure disc unit has a glitch in the coupler device. You can fix it by moving the shifter up and down and not pressuring the lifter when you see the red light come on, but your girlfiend should not be looking at it when that happens or it will never go into gear 2 while warming the gearbox up three times and cleaning the filter to let the fluid drain into the lower case box.
If that made any sense to anyone then they should be able to diagnose this transmission problem. I have been working on my cars as a hobby for many years and worked on them as a mechanic a while back and I still can't tell if he is trying to fix a manual transmission, automatic transmission or trying to fix the muffler bearings.
Good luck with it.
Russ
