How do i check the codes do i need to go to a service center ?
Also if i start the car from cold the revs idle at 1000 rpm and runs ok if left switched on.
If i run the car for 5 mins and restart it it idles at 500 rmp and can cut out and needs to be run for 10 - 15 mins before the car will idle at around 1000rpm without cutting out.
I have changed the plugs but still no joy.
Any ideas please ?
Thanks
