Originally Posted by supraman121
What seals would it burn up? It just a exhaust i can see how it would mess with the power but seals?
The only possible damage it could do is (this is rare), when the outside tempeture is cold-- really cold-- the exaust pipe will build condensation. This can travel to your exaust valves. Then when you start the car ---WARP!
But a friend of mine has an N/A with three inch straight pipe and he loves it.
I would not worry about the bottem end power.
Also if you need back pressure and a bend at the end of the pipe when installing.
