http://www.supramania.com/forums/showthread.php?t=2409
suprra_gurl tells the spec and the 89 turbo is slittly better then the 7mgt and sence it is a turbo or they both are a turbo you still can have better hp out puts then just the normal na engine but the 7mgte swaps right in you can use the tranny and everything in the car right now but you need the wireing harness
