Thread: Wastegate?
Old 01-09-2007, 06:37 PM   #4
drmmr15
drmmr15 is on a distinguished road
Im sorry, the reason I think its the wastegate stuck open is I couldnt FEEL an exhaust leak, but I could hear a steady hiss coming from that area. This leads me to believe that the wastegate is dumping into the O2 housing a bypassing the turbine, making no boost. Does that sound correct?
Edit - Wait, so it must be an exhaust leak, youre right. Otherwise, even if the wastegate is dumping into the exhaust system, the car should die when I block off the exhaust, unless there is a large leak somewhere. I think it could be the turbo to manifold gasket. I hope the turbo isnt screwed. I'll diagnose the problem further. Thanks for the input.
1987 Supra Turbo
GReddy TT
Open Element Filter (<---not sure what brand)
YAY BOOST!!!!....finally...
drmmr15 is offline   Reply With Quote
