Old 01-10-2007, 10:28 PM   #49
IHateHacks
IHateHacks's Avatar
Thank you!
I already ran a bottom tap through the 14 head bolt holes in the block. I'm still going to use brake cleaner and blow the holes out with compressed air.
I test fitted the bolts and I noticed that you can just barely fit a 3/8" drive 14mm socket in between the lifter bores. The walls are machined (from the factory) just enough to fit a 14mm socket. It's like they did it just for ARP bolts (I doubt it!). It's nice to have something work out in your favor once in a while (or just once).
