Originally Posted by tone loc
if you want to put in a 2jz its ganna cost 5-6000. not really sure how to do it though. i know you will need a new trans new ecu , engine mounts and couple of other parts.
Was this a qoute for installation as well? cause i thought the 2jz just the engine was like 2k and i dont even now how much the tranny and the ecu cost the new wiring harness and then you got to spend the money to get the old tranny/engine mounting brackets removed and if your 5spd going to six would you not have to replace the clutch? clutch kits for the 2jz are not exactly cheap?
Go for the 7mgte swap fits right in and you can use the orginal tranny for a while and for like 6k you can put better injecters and bigger turbos on the engine have it installed and be pushing nice power to the ground but dont do it on the w58? i think that is the tranny in our 86.5's
