Wont Start
I have 87 7mgte, it cranks but wont start. I've run all of the diagnotic tests I can find, but still can't isolate the problem. I replaced the ECU today and tried cranking it again. No luck. I shorted terminals E1 - T, and now my check engine light isn't comming on. I've check all of the fuses I can find, none are blown. When, I short terminal W to body ground, the check engine light comes on. I'm getting the same results with two different computers. If the check engine light doesn't come on, is that a sign that the ECU is not getting power? If so, is there anywhere I can check for a inline fuse that I may be missing?
