01-13-2007, 03:40 PM
#59
AEM EMS
This may be an alternative to welding, they manufacture allsorts of polymers, aluminium epoxy putty etc for repairing worn or damaged castings and shafts; you would need to check out the temperature resistance. Many years ago I repaired an air-bearing surface on a granite bed CNC PCB drilling machine, it set as hard as the granite. I also remember it was quite expensive .Many be worth contacting them for some advice.
http://www.devcon.com
http://www.devcon.com/maintenance.cfm
http://www.devcon.com/devconcatsolution.cfm?catid=16
