turbo
right you are right my bad then check the cam position sensor that is where the dist used to be and it had coilpacks so there is more inplay than just those now you need to check the ignition module too make sure its doing its job
thanks damdog for correcting me and the coil packs if more than one usually dont all die together if there is no spark
