Old 01-13-2007, 05:36 PM   #16
kwnate
SP58GT
667rwhp 7m on a built bottom end @27psi, it will easily pass the 700 mark with 264 cams and an etra 3 pounds of boost. A friend of mine has a bigger turbo and should be around 760 on boost, 850 with nitrous. Both of our cars have well over 35k in mods. Its not a cheap deal if you want it to last.
With the jz motors you don't need to build the bottom end as long as its in good shape, but that only saves you around $4,000, that cost will be offset with the need for a 2j motor, wiring, bellhousing. Then you can start to mod your turbo setup, intercooler, fuel system, tuning device. $$$$$$$$
Good luck with your choice
Nate
